I’m a new user.
I imported a song to cut for a ringtone. I can play the song fine but it’s loud and I can’t find a way to adjust the volume in Audacity. I have looked and looked.
I try adjusting the volume on my macOS keyboard but it makes no difference if I turn off the sound or move the dial up and down. No change in the volume. Is there a volume adjust on Audacity and I just didn’t see it?
Thanks! It was so small I didn’t see it. I got it bigger and I got it working. Appreciate your help.
