Voicelive 2 or 3 or any TC Helicon Voice live unit
I am curious if anyone has used either of the above 2 products with Audacity? If so what have the results been like. I have tried asking the manufacturers about using them with Audacity but they just reply that they think they would. I really want to know if they do before I commit to £300 or so to buy. Help will be appreciated. Annoucka. I am using Audaity 2.06.
Someone here was using a Voicelive 3: link to the post
I’ve not found anything else relevant on the forum. You might try searching the Internet with Google or other search engine.
Audacity 2.0.6 is obsolete.
Unless you are using Windows XP you should update Audacity: http://www.audacityteam.org/download/
