voice remover
Hello,
I want to remove the voice in an mp3 file but it doesn’t work.
Can anybody help me please.
Thanks
Probably not.
Select the whole song by clicking just above MUTE.
Effect > Vocal Removal > Enter.
If that didn’t work or at least do something, then your song may not be a good candidate for vocal removal.
Mono song tracks (one blue wave) do not work at all. Stereo Shows with the lead singer not in the left-right middle don’t work at all. There is a long list of musical tools and effects that can be applied to a show that sound terrific, but mess up vocal removal. High MP3 compression can mess up Vocal Removal.
My lists are out of date, but there is a new Vocal Removal and Isolation available I think in Audacity 2.1.0 and 2.1.1. But that one is an improvement on the older one. If the older one didn’t do anything, I think your only hope is search for a karaoke version of the song to buy.
Looking for the new tool…
Vocal Reduction and Isolation is new in 2.1.1 and it is documented at http://manual.audacityteam.org/o/man/vocal_reduction_and_isolation.html.
