voice editing help
what is a good way to make your voice sound better as in crisp and clear with the ffect button? like i sound like im too close to the mic and is a bit sluggish even though ive tried to keep my head away farther. i have a pop filter btw along with a mxl 990 mic
You should make a sample of your work mono (Tracks > Stereo Track to Mono) and export it as FLAC format. Post it here on the forum so we can hear what you’re doing. “Upload Attachment” from the tab below the text composition window. The forum cuts you off at about 1MB, so you won’t be able to upload hours of work.
Alternately, if you have any work on YouTube or other public system, tell us where.
There is no button to “make it sound better.” We have to work from where you are now. Also, point to voices you like.
See here: https://forum.audacityteam.org/t/vocals/23333/1
Try pointing the mic at your nose…no kidding!
