Vocals + Effects
Is there a way to use the effects JUST on the vocal tracks and not on the music tracks?
If you have the vocals on a separate Audacity track, then just double click on the track to select it and apply the effect.
If the vocal and music are already mixed together on the same Audacity track, then no you can’t.
