Hi everyone
For a few years I’ve been making recordings of my vinyl records using a hifi CD recorder (Sony RCD-W100) connected through a DJ mixer (Pioneer DJM-600). But I decided to upgrade my DJ setup and “go digital” with a Native Instruments Traktor Audio 6 soundcard, which meant I could sell my mixer and cd recorder to clear some space.
Also making recordings without a mixer in the way should mean a theoretical improvement in accuracy as well as meaning I don’t have to rip a CD each time.
Audacity version is 1.3.13-beta (Unicode)
Computer is Windows Vista 32bit
Turntable is a Technics SL1210mk5 with an Audio Technica AT120E cart, aligned with a Baerwald arc protractor
Sound card is a Native Instruments Traktor Audio 6… http://www.native-instruments.com/#/en/products/dj/traktor-audio-6/?page=1964
It’s designed for digital DJing but the specs look good and it has switchable phono inputs. The inputs are switched to phono mode.
I’ve been testing this out for a few days and I’ve got some questions.
I just want to make sure I get my workflow nailed before I start working through my records.
Here’s a screen shot of Audacity whilst recording… http://www.highbeeches.plus.com/recaudacitylevel.gif
Is my recording level acceptable?
Is that to be expected? Or does this point to some sort of hardware problem or some hidden volume configuration in Windows Vista that I’ve not found yet?
I’ve got all level sliders that I can find set to the maximum but the peaks of my recording still seem to be <0.5
Here’s a screen of the Vista Recording Devices property page showing the level set to max, this slider is linked to the one in Audacity… http://www.highbeeches.plus.com/recinchannelproperties.gif
Previously I used to increase the gain on my mixer so that the peak was just below clipping, then set the recording level on my cd recorder to the same. But it seems with this sound card I’m already at the maximum. -
I guess I can artificially raise the level using either the amplify or normalize effects per this wiki… http://wiki.audacityteam.org/index.php?title=Amplify_and_Normalize … since it appears I’ve got it set to the maximum possible level at every stage I can find.
But by doing that am I losing quality, or making my recording sound worse?
Because by increasing the level, I’ll also be increasing the level of any distortion relative to silence.
Or is applying those effects (even to the extent that I need to) just an accepted part of ripping and archiving vinyl records? -
I’m not an audiophile mentalist but I like to get the best result I can with the gear I’ve got. The NI Audio 6 sound card supports a 96kHz sample rate and 16bit/24bit format.
Should I bother recording at a higher sample rate/format? -
What’s the best lossless format to export?
I normally keep all CD rips in FLAC, can FLAC support 96kHz? From the export options it seems FLAC can handle 24bit.
I will also keep a 44.1kHz/16bit version for more convenient playback.
But for archival purposes I think it makes sense to go high-res since I’m bothering to do this and my hardware supports it. -
I’ve got the sample rate set to 96kHz in the Traktor sound card’s proprietory control panel utility, there’s no option for bit rate.
But do I also need to set this in Vista’s Recording Devices Advanced Properties for my input channel per the options in this screenshot… http://www.highbeeches.plus.com/recinchannelpropertiesadvanced.gif -
Audacity supports 32bit float sample format but my sound card only supports 24bit. So I guess going with 32bit float is unecessary as the information coming in is 24bit, is that right?
When changing the “Default Format” under “Advanced Settings” for my input under “Recording Devices” in Vista to:
2 channel, 24 bit, 96000Hz (Studio quality)
The recording level is almost zero, slight 1-3 pixel peaks are seen on the graph.
But if I change it to…
2 channel, 16 bit, 96000Hz (Studio quality)
Then it comes through fine.
Does that mean I need to also tell the soundcard hardware to output 24bit instead of 16bit?
Or does it mean that there’s some other problem? -
Is there a way to set the output/input level monitors to default to linear instead of dB scale? I have my tracks set to default to linear in Audacity’s prefs.
Software playthrough. I don’t have a hardware playthrough option so software playthrough is the only way I’ve found to be able to hear what’s being recorded.
My machine seems to be able to handle the load, it’s a chuddy Toshiba laptop with 4GB memory and an Intel dual core T2250 at 1.73GHz.
But is it recommended to turn that off to prioritise the recording?
I realise these questions must get asked all the time on here. I’ve only ever used Audacity for chopping around existing tracks. My recording use of Audacity was with an earlier version and under XP so things have changed quite a bit since then. It seems the sound device options for Vista are spread all over the shop but something that appears to be much improved in Win 7.
And I guess everyone’s setup is always slightly different, with different combinations of computer hardware. I just want to make sure I’m not missing anything so I don’t find out in 18 months’ time that I missed a checkbox somewhere that prevents me getting the best output I can within my time and budget.
I’m also not bothered about removing any pops/clicks from my vinyl recording. To me that’s part of the recording and could always be done at a later stage.
Thanks in advance!
Cheers, B
