very wired sound
Hi All,
I have a recording where the voice sounds very wired :astonished: - someone could say robotic. Is there a way to clean something like this http://www.stami.ch/transfer/public/strangevoice.mp3
Your help in this is greatly appreciated! :exclamation:
Jusjus
Can we assume the original was somebody playing natural instruments, not electronic music?
I’m going with no. Someone created a very damaged sound file. It could be sampling errors or a marginal sound file that sounded OK to listen to straight, but once compressed into MP3, turned into trash. The obvious error is the gargling, bubbling instruments, but a lesser clue is the snapping that drifts through the piece. That’s pretty deadly.
The video people have a tool to cure this. The “Reshoot FIlter.”
Hi,
thank you very much for your tipp - I’ll try to find a reshoot filter…
It was a plain speech which was live recorded - hence we didn’t notice anything. I figured till now out that it was indeed most likely a mismatch in the Sampling rate. As a matter of fact I switched now to ol’ Analog recording.
Thank you for your help in this!
