A recent round of updates brought in Audacity 3.7.1. It is completely unusable. Whenever I try to run an effect, it dumps core. Instantly. The previous version I had was 3.5.1. It worked without problems.
I renamed ~/.audacity-data to force a complete configuration refresh. That did not work.
The host system is Fedora 42. I use Audacity as packaged from the Fedora repositories.
I can provide a coredump file, but it is 17 megabytes. Too big to post here! I generated a support zip file. Is there a way to attach it here? I have a text output from abrt which lists a bunch of libraries and a call stack. I can embed that text here if you don’t mind close to a thousand lines of stuff.
Where do I go from here?
Thanks - Bill Gee
