[Version 3.6.0] Custom mapping export crash
Good evening.
I just installed the latest version 3.6.0, when I try to export a multichannel file (6ch) in Wav format lasting 2 minutes with custom mapping, Export entire project interval.
Audacity crashes, showing me a report log but which I can’t send, so I copied it to notepad and put it on the server for further investigation.
I did the same test with the previous version (3.5.1), I don’t have any problem it is ok.
Thanks
https://justpaste.it/e553t
thanks for the report. We’ll look into that tomorrow.
I didn’t think there was a multi-channel WAV (Microsoft). You always had to use one of the formats that were specifically designed for multi-channel (over 2).
OK, so. Apparently, it’s a thing.
I think I’d be concerned with who’s going to play that.
This is what happens when I try to export the multichannel file.
One thing I wanted to ask the developers, if it is possible to have the dark interface from version 3.5.1 as a custom file that can be used in version 3.6.0 as well I would be very grateful for that.
Resolved!!!
With the latest version 3.6.1
Thank you very much :+1:
