Version 3.3 and old instalation
I have installed 3.3 and it is operational. However if i use the facility of ‘open with…’ from the file manager, it open the previous verson and not 3.3. Advice please
Yes, so I would start by uninstalling the old version of Audacity.
Then right-click on your file, Open-with, check Choose another app, scroll-down if you need to, then if Audacity doesn’t appear, “Look for another app on this PC”.
