Version 3.3.2 slow to open
Running win10. I believe Aud is slow to open because of missing files. Error log (below) shows missing avformat-60.dll. I installed the latest FFmpeg which fixed other missing files. I can’t locate the -60 file. Any help appreciated.
17:35:06: Audacity 3.3.2
17:35:06: sqlite3 message: (1) no such table: project in “SELECT 1 FROM project LIMIT 1;”
17:35:06: Error: Failed to load shared library ‘avformat-60.dll’ (error 126: The specified module could not be found.)
17:35:06: FFmpeg libraries loaded successfully from: C:\Program Files\FFmpeg For Audacity\avformat-59.dll
Good question. Note that FFMPEG is not part of Audacity. You could ask on the buanzo site, or you might be able to get an good answer from the Audacity developers directly: Discord
