Vamp Plugins
Hello. I would love to install the Queen Mary Vamp Plugin but it seems I cannot get it to work. I reinstalled Audacity, deleted EVERYTHING related to the plug and Audacity but still. No good results. I have 64bit so I put the Vamp Plugins folder into Program Files(x86) with the .dll I still cannot see why it does not show up in my Audacity plugin list. I enabled every plugin. QM Plugin is not even on the list… Send Help! :frowning:
If I recall correctly, there is a bug in the most recent version of the Queen Mary Vamp Plugin that prevents it from working.
I’ll check…
Found it - You need the “qm-vamp-plugins-1.7-win32.zip” from here:
https://code.soundsoftware.ac.uk/projects/qm-vamp-plugins/files
Installation instructions: https://manual.audacityteam.org/man/analyze_menu.html#vamp
Thank you so much!!! I can’t believe I just used the wrong version. lol. Thank you! :smiley:
