Can I have v3.2.1 and v3.1.3 on the same Mac? I’d like to try the new version but want to be able to go back to the old version easily, if I have any problems.
Thanks
odododododod
Mac M1 RAM 16GB running MacOS v 12.6 presently on Audacity 3.1.3
I can sense programmer/developer’s hair standing on end. I think if that works for you, you’re just lucky.
There’s an odd place you’re inviting troubles. If you run into an actual program bug or code damage, you won’t know if it’s an actual bug or a result of your name change.
Note that version 3.2.x will mess with your preferences if it is opened after an earlier version (for example, 3.1.1) has been opened. There are apparently enough differences between the preferences that the developers felt it was safer for 3.2.x to return to some defaults. 3.2.x will also re-enable all the default effects.
There is a way for each version of Audacity to have its own preferences, but I’ve never tried it.
Portable? I’ve never tried it, either. The down side if you have to install all your custom settings and extensions for each one. If you do things the way I do, you leave one out. “Son of a sea cook! Where did I put the framistat filter?”
Many thanks for the replies all. I decided to take the plunge. Point noted about renaming the app. That is something I’ve often done, also without any problems so far.
