versione di windows: windows 7
versione audacity: ver. 2.0.5
programma di installazione da .exe
ho installato una scheda audio steinberg ur 12
quando registro una nuova traccia in audacity(chitarra, voce) registrra sulla stessa traccia anche la traccia della base(cosa che con la scheda del pc non faceva)
ci sono particolari settaggi da attivare
I have the same problem and have been looking for a solution for ages. Thanks. However, I have a problem: I cannot find the control panel of the Yamaho driver in Windows 10
When I click control panel > Hardwaree and Sound > Manage Audio Devices
I just get the standard Sound window. When I click recording and Select UR12, and then right click for its proporties, it there is an option “Listen to this device” which is disabled.
It has been like this all the time, but I can’t record sounds with Audicity.
So, how do I disable this loopback option you mentioned?
Thanks,
Xan.
