Using VSTs in Audacity
Hi Just downloaded last version of Audacity and under Effects a lot show up. I downloaded some VSTs (dll files) from the audicity web site and copied them into the plugin folder per instruction on Audacity site (drag the dll files into the plugin folder from my computer’s download folder), and set my Effects preference to allow rescanning of VST when restarting the program.
When I restart the program I see the new VSTs being scanned (plus some from my Cakewalk folder which I used years ago), but when I start the program I do not see any of the new VSTs that were scanned show up under effects. Am I missing something?
I am running Vista 64 bit and have had no problems with Audacity previously
Not sure if replies will show up at my email address so here it is if you can contact me directly:
Moderator note: I removed your email address, this site like many others gets visited by spambots harvesting real eamil addresses - I’m sure you don’t really want a flood of spam :slight_smile:
thanks!
could be a problem specific to Windows 64 bit … https://forum.audacityteam.org/t/vst-effect-question/28015/1
Hiding the cakewalk VSTs so Audacity does not attempt to load them may be worth a try … http://wiki.audacityteam.org/wiki/VST_Plug-ins#locations
Audacity choking on an incompatible VST from your cakewalk folder, preventing completion of the VST scanning process, may explain why there are no VST effects in your Audacity effect menu.
