I’m running Audacity 2.0.2 on a Windows 10 Pro and I’m editing a large (more than 2 hours) audio file.
Ideally I’d like to use my mouse (wheel) to scroll forward and back through the file and use the left button to start and stop playback and the right button to add begin and end marks to allow extraction/export/deletion of sections.
Ctrl + Mouse wheel to zoom in/out
Shift + Mouse wheel to scroll horizontally
Mouse wheel scrolls vertically if you have more tracks than fits on the screen
Mouse events are not currently customisable. Look in “Edit > Preferences > Mouse” for the full list.
One last question. Say I’ve advanced to a point in the file perhaps 5 minutes into it and I want to select from there back to the beginning as a selection for export. At the moment I’m scrolling back and takes forever; is there a quicker way?
And, finally (sorry , is there a way of adding markers to a long recording that Audacity can quickly skip to? Supposing I’m recording a singing session and there are songs interspersed with periods of chat etc. Is there a sort of audio clapperboard?
I scroll through till I’m where I want to be then I use the mouse to mark the position with a thin vertical black line then I drag that line back to he beginning to highlight the section I want to export.
I meant adding markers during the time the recording is being made like a film director uses a clapperboard to mark starts and not after in editing.
I read that but it’s based on your being inside Audacity during recording time but that’s not my situation.
I set up a digital recorder (an Olympus LS10) and let it run through an entire session; some 2 hours or more. I then offload the recording to my PC where I get to work on it with Audacity.
If there was a means of recording start and stop points that Audacity could find that would be brilliant.
That is an Audacity “feature request”. The standard method would be for the recorder to add embedded cue points into the WAV file. Some audio editors can see those points, but Audacity cannot.
