I installed Audacity from the dmg and am using Mac OS X 10.6.8
I am using Audacity to copy a cassette tape from a cassette tape player to an .aup file on my computer.
That part works OK. My problem/question arises in trying to use the Metadata Editor in Audacity.
What I thought I could do is edit some metadata file which Audacity had, and which had information (such as what I typed into its “Comments”) - and when I saved the project (generating aup and data files) that metadata file would be saved also. In that case,upon reopening the saved project, and opening the metadata editor, I would see what had been previously typed into the metadata editor.
Well, that’s not right. I can edit using the metadata editor, save the project, reopen it and upon looking into metadata editor will see text different from what I had originally put in.
So what is it that the metadata editor does?
