I have Audacity 1.2.3 does anyone know what effects I need to use in what order to turn a male voice into a believable female voice ?
Lee
Use the Change Pitch effect. However, you wonāt necessarily get a ābelievableā female voice, things can get kind of weird when you start pitch shifting.
Ok Iāll try that, does anyone else have any suggests to go along with this ?
Lee
Depends on your definition of ābelievableā.
Iāve never heard a convincing male ā female edit. Furthermore, I donāt think itās possible without synthesizing the female voice from scratch and using the male voice as a guide. At this point in time I donāt think anyone has any software that will do that.
If you want a convincing female voice, you have to have a real female or a male who can do a very good impression. Or a eunuch, I suppose.
Oh thatās easyā¦
Are there any MARRIED MEN out there available for a voice over ?
Lee
We just happened to have beaten this up in an older thread.
http://audacityteam.org/forum/viewtopic.php?f=26&t=1876
