Using effect on split out region deletes clip splits into the original clip
Audacity 4.0.1:
select a segment, label, and split into a new chunk or region
apply certain effect (for example delay or vocoder or tremelo but NOT reverb)
when applied the effect dissolves the labeled clip chunk or region that was split out from the full clip, back into the whole original clip and it is no longer a separate clip.
i haven’t tested all the onboard effects, just noticed this when testdriving 4. reverb worked normally but delay dessolved the clip borders and the region effect was there but it was all one clip again.
This sounds like this Github issue. This means that the developers are aware of it and have identified it as needing to be fixed.
