Using Change Speed to effect pitch
I’m finishing up an EP and I’m interested in 444 hz tuning. I want to experiment with converting 440 hertz tuned tracks into 444 hertz using change speed. What percent Change would I need to apply to raise the hertz by from 440 to 444?
~Angelo
Run Effect > Change Pitch and put the two numbers in their places near the bottom, but don’t apply it. That will calculate and present the percent number.
Thank you thank you thank you!
It’s so simple :slight_smile:
