Using Audacity for nearly 2 years and its suddenly stopped?
I was using an older version of Audacity and it had been working fine for over 2 years, all of a sudden, it stops working for no reason and not because I have changed ANY settings.
Im recording from vinyl / cassette sources through the OUT option on my amp, which is also the same as what I had been doing.
I am using Windows 7 Home Professional and I have updated Audacity by installing the latest version - audacity-win-2.0.6 hoping that would rectify the issue. Regrettably, it did not.
I am used to changing the preferences [between Mapper and Stereo Mix Realtek] for different types of recording, but changing preferences and restarting make no difference any longer.
All I hear when I attempt to record into the microphone socket, is myself speaking, even though I have a cable going straight into the mic socket?
ANY HELP truly appreciated.
Thanks in advance.
BTW.
I have updated all the sound drivers, and want to highlight that the issue remains the same whether the microphone jack is in the mic socket or not?!!??
I presume that you computer is a laptop with a built in microphone.
Look in the Windows Sound Control Panel to see what recording device is set as the default. Set that to the input that you want to use.
Then open (or restart) Audacity.
The “mapper” input in the Audacity device toolbar selects whatever is the default in the Windows Sound Control Panel.
You can either, use “mapper” (assuming that is set in the Windows Sound Control Panel to the input that you want to use, or explicitly select the input that you want to use.
Note: If you have Skype or other “voip” application, ensure that is completely shut down before you start. Skype is known to “hijack” the sound system (which it needs to do to be able to work properly).
Many thanks Steve.
Yes, laptop, but sadly no joy.
The recording device setting default is the same as the setting on Audacity.
No Skype, no other programs open.
I’ve restarted the LT as well as restarting the actual program.
No joy.
All I hear is the external sound, even if the cable is in or out of the mic socket.
Im lost
What is an “LT” ?
Sorry fella, I’ve restarted the LapTop as well as just restarting the individual program.
When you’re in the “Recording” tab of the Windows Sound Control Panel, you should see a green meter jiggling up and down when the sound card is receiving sound. Is that happening? If so, is it responding to your “vinyl / cassette sources through the OUT option on my amp” or to the laptop microphone?
If recording into the external mic socket gives you acceptable quality in your opinion, then choose the external mic as the Recording device in Audacity’s Device Toolbar. If you don’t see the external mic, enable it in Windows Sound, as per http://wiki.audacityteam.org/wiki/Mixer_Toolbar_Issues#vistacp.
If you want to hear the signal coming into the mic socket while you record it, turn on Transport > Software Playthrough top of the Audacity window.
@Steve - It does jiggle [love the description] but will only recognise the external sound, whether the cable is in or not, therefore all I hear when I attempt to record into the microphone socket, is myself speaking/ clapping etc
@Gale - Thank you sir but sadly the external mic is already set as the default recording device and it makes no difference.
I’ve also double checked by attempting different sources going into the laptop, but no difference.
It seems that your computer may no longer recognising that you have something plugged into the socket.
Carefully examine the cable, and in particular, ensure that it is plugged into the correct hole on the laptop (I know that sounds obvious, but these things do happen :wink:) and check carefully, when plugging into the laptop, that it “feels” right (the sockets can sometimes become detached from the circuit board inside the computer).
Yeh, correct sockets being used and still no joy. I’ve also installed other software too, and THAT doesnt work either.
Maybe the internal has come away from the circuitry etc. NOTHING else seems to work, and this happened outta the blue so it must be that.
#gutted
Thanks for all your help.
Does recording from Stereo Mix still work?
Nope, same problem, all I get is the external mic which records my voice etc…
Im so lost now.
Ah ha, now that is strange - I don’t think that is likely to be due to a hardware fault.
Do you know how to “roll back drivers”? If you do, see if the sound card drivers can be rolled back to an earlier version (Windows may have updated the drivers for you and caused the current problems)
This link may help http://wiki.audacityteam.org/wiki/Updating_Sound_Device_Drivers#Windows_Update.
