Use Audacity as amplifier
Happy New Year!
Is it possible to record and output an audio signal at the same time?
I got an mic which I can plugin through USB and a small speaker attached to the audio output.
It works fine to record the signal and play it back later, but how could I send it to the speaker simultaniously?
I prefer to use Audacity for this, in order to record the signal at the same time.
If I can’t do this with Audacity, is there another way?
Thanks in advance for your kind help.
Frank
PS: I am using version 2.3.0 with Windows 10, a t.bone MB88U mic and a Sony SRC-XB31 Extra Bass speaker
There is always latency (delay) through the computer and sometimes it can be a problem for real-time monitoring/performance.
Some “podcast” microphones have a headphone jack for direct zero-latency monitoring. You can plug powered computer-speakers into the headphone jack.
If you enable [u]Listen To This Device[/u] you can hear the microphone without Audacity (or any other application) running.
Or in Audacity you can enable [u]Software Playthrougn[/u].
Thanks a bunch. That works for me.
