USB turntable recording too loud [SOLVED]
Hello there,
User ‘Bill’ very kindly helped me to get up and running with USB turntable recording / Audacity software.
Having now done that and saving as an MP3 etc, the playback sounds awful - as though something is turned up too high.
How do I adjust settings?
PPOOMM
Does the playback sound bad in Audacity, or only when you play back the MP3?
– Bill
Both.
Choose View > Fit in Window then View > Show Clipping. If the track now shows a mass of red vertical lines, you recorded too loud.
Yes - lots of red!
How do I adjust settings so I’m not recording too loud?
Cheers.
PPOOMM
See this FAQ in the Audacity Manual: http://manual.audacityteam.org/o/man/faq_recording_troubleshooting.html#clipping
Thanks Wax - I think I have it all sussed-out now.
Good forum this - prompt responses are much appreciated.
Happy New Year.
PPOOMM
