Will a usb audio interface connect to a usb mic - I am looking to improve quality of recording rather than playback.
A usb soundcard is out of the question since it won’t connect to my usb mic.
No. A USB mic plugs directly into a USB port on your computer.
It seems that you already knew the answer.
In most cases, changing the motherboard or even changing the whole computer will make no difference to sound quality.
The two exceptions to this rule are:
Dealing with fan noise:
WARNING: Never cover, block or otherwise obstruct the airflow around the computer. Doing so can cause the computer to overheat and cause permanent damage and may pose a fire risk.
Please post a sample of the recording so we can hear what is wrong with it.
Have you made that overdub recording yet, so you can tell if recording with the USB mic and playing with Realtek makes the beat drift apart? Please do that and tell us the result before posting any more questions. If the tracks are not drifting apart then you may not need another recording device.
Ok I’m not going to mess with any other soundcards, motherboards or anything. And i’m not sure what made you think this - but computer fan noise is not an issue I have.
Also I’m not sure where I said anything was wrong with any of my recordings - I just want to improve the quality of my recordings and secure the settings i want to use before I record any more material.
I thank you for resolving my pitch problem but the issues I have now are separate to this problem.
If nothing is wrong with them, what is your concern?
We will not answer your questions again about “securing your settings” because we have answered them multiple times already.
If you have $1000s in the bank, why not spend it on new equipment, and see if you can hear the difference with the recordings you have now?
If you cannot hear the difference, and no-one else can, then you wasted your money.
If you had posted an audio sample then I would have known that.
As you haven’t I was covering possible issues that might make you ask about upgrading your hardware.
If there is nothing wrong with your recordings then don’t change anything. Few of us are able to achieve perfection, but if you have then keep going and don’t change a thing.
