Upper half of track missing
Windows 10, Audacity Portable 2.2.2.
Please see screenshot attached: upper half of the track has disappeared.
Did I accidentally hit a button or something? Not sure how to restore it…
Thanks for any bright ideas…!
Post another shot this time with the left scale (volume) visible.
Somehow you have made a vertical zoom
Right-click in the vertical Scale ( the vertical bar between the waveform and the Track Control Panel) and select Zoom Reset
See this page in the Audacity Manual: https://manual.audacityteam.org/man/vertical_zooming.html
