updating
Hi, [Advert removed by moderator] - can someone tell me in English how to update this program. I really would like to go back to podcasting and its Audacity that is holding me up . I have Audacity 2.1.3 now and frankly uninstalling it and downloading it again and reconfiguring everything scares the hell outta me. - I am running the latest version of windows 10 - and use the Geek Squad so I am Malware Free to
  1. Uninstall Audacity (see: https://support.microsoft.com/en-gb/help/4028054/windows-10-repair-or-remove-programs)
  2. Download “Audacity 2.2.2 installer” via the text link on this page of the Audacity website: https://www.audacityteam.org/download/windows/
  3. When the download is complete, visit this page https://md5file.com/calculator and upload the file that you have downloaded.
  4. When the “SHA-256” result appears, ensure that it is:
    ca19471e10660765dec12c980ebd3eeb9b82826ea4f25bc490936f312b14caff
    If the numbers do not match, then the file has not downloaded correctly, so you will need to re-download it.
  5. When you have downloaded the Audacity installer and checked that it has the correct SHA-256, double click on the file to run it.
  6. Follow the on-screen instructions to complete the installation.
If you simply run the installer it will update and keep your settings by default. (There is a an option to reset your preferences if you want.)
Of course things can go wrong, but I’ve never had a problem updating Audacity. I try to keep it up-to-date. (I don’t install the Alpha versions, just the official releases.)
…I do have a general rule to “never update in the middle of a project”. If you’re half-way through making an audiobook, I wouldn’t mess with anything. :wink:
