Updating
Hi there
Just wondering about upgrading audacity version from 2.0.5 to 2.0.6 what lameMp3 and FFmpeg plugin’s do you need with version 2.0.6 ,bit confused with the audacity web site help info !
Running XP 32bit Thank You !
Jack
Why are you updating?
Whereas you can stop anywhere in the update path, I believe the party line is to go all the way up to 2.1.2. The program and associated Lame and FFMpeg are available from here.
http://www.audacityteam.org/download/windows/
If you look at the direct link to the FFmpeg FAQ you can see that you will need to update FFmpeg to 2.2.2 if you upgrade past Audacity 2.0.5. You don’t need to update LAME.
