Updates
I would like to know how can I update audacity from 2.1.1 to 2.1.2
Download one of the two Windows versions from here:
http://www.audacityteam.org/download/windows/
…and launch it (or decompress and launch it). The Windows version has an installer and should guide you through the install process.
It is intended that you do a straight, simple install and the new Audacity will automatically pick up all the preferences and settings from the old one. If you want to start over, there’s a place in the installer where you can select Reset Preferences.
