Updated to version 3.7.7, now it won't record anything
I updated to the new version today and now the program will not record anything. I started a recording an LP and the program just stopped recording near the end of side 1. I tried to re-start the recording and it simply does not record at all. I restarted the program and it still will not record anything.
Neither can I. Just get error code.
Its now unuseable…
You have a computer (Yes/No)?
It has an operating system? Name of the OS, and what version?
What are your settings?
What did you try with what result?
For me, Audacity works great.
If you could tell us more, I think we could help you better…
I am recording vinyl lp’s for personal use so I do not have to play the physical copy every time I want to listen to them. I am using a Dell Precision Tower 5810 running Windows 10.0.19045. I have made thousands of recordings with Audacity and never had a problem until this update.
Here are my settings:
try a different audio host … Tutorial - Selecting Your Recording Device - Audacity Manual
