I have down loaded a narrative cassette tape to my laptop and want to up load it to facebook. what format should I use? And how long will it take? Tape lasts 43 minutes.
That’s up to Facebook. What do their instructions say? Do they even let you upload long-form recordings like that?
That’s scary. This Google search term doesn’t return any valuable hits.
facebook audio uploads -video
So maybe you don’t. Or not without converting it to a movie. Lots of video upload instructions.
I have no idea, but you might need to upload to SoundCloud or some other file sharing site and put a link to it in Facebook.
Or, you can make a video with a still image (it could be a “picure” of text, such as the title of your narration, etc.). Windows Movie Maker can probably do that if you don’t have a video editor that you normally use.
MP3 or AAC (MP4) are the most popular compressed formats.
That depends on your connection speed. (Usually, uploading is slower than downloading.)
A high-quality music MP3 (~256kbps) is about 1/5th the size of uncompressed WAV from a CD… About 2MB per minute. With spoken voice, you should be able to get down to less than 1MB per minute. But, 20-40MB is still a rather large file and it’s going to take some time.
The bitrate (kbps) is kilo_bits_-per-second, and it’s directly related to file size (there are 8 bits in a byte). Higher quality settings will create bigger (higher bitrate) files.
There is a video here that describes “sharing” the audio from SoundCloud:
http://www.youtube.com/watch?v=VJupvsisOUM .
That’s what I ran into. You can post the sound Somewhere Else and point to it.
You can upload videos to Facebook , (rather than use an embedded YouTube player), but not audio …
https://www.facebook.com/help/154271141375595/
