unwanted click track :( [SOLVED]
Hi guys!
For whatever reason I’m getting an unwanted click track (an actual track with accent on first beat) when I try to record another track onto my song. It’s not there as a separate track, just in the background on the track I’m trying to play on and I can’t get rid of it! It’s driving me even crazier than I already am!
I noticed this right after I used the Change Pitch effect. Any suggestions??
Thanks a bunch!!
This is the only “Click Track” in Audacity, and you have to specifically go to the Generate menu to generate the click track:
http://manual.audacityteam.org/o/man/click_track.html
First, thanks for replying so quickly! But yea, it sounds exactly like that one, which I’ve used in the past. Only I didn’t actually generate this one, it doesn’t have a dedicated track, it is unseen and haunts me endlessly like a cursed hellghost. I believe it is actually devouring my soul as we speak.
It comes up whenever I try to record and when I select Start Monitoring. Even tried starting a new project and still its endless clicking returns.
Just baffled. Pretty easy to do, but still!
AHHHHH!!! You’re right the metronome sound was coming from my effects processor!! Sounds exactly like the Audacity one. Sheesh. Thanks again!
Glad you found it :smiley:
I’ll mark this as solved.
