For several months, I’ve been using Audacity 2.4.2 to record directly from a USB mic plugged into my windows 10 computer, have had no problems. Tonight I am unable to record. When I press the record button, nothing happens. Nothing appears on the track, the cursor does not move.
I checked my mic and troubleshooted it in the sound settings on my computer and it’s working fine.
(FYI A couple of months ago I tried Audacity 2.2 or 2.3 and didn’t like the interface, so I went back to version 2.4.2, which as I said has been working fine.)
The only thing that I see in the Audacity interface that I have not noticed before, are two red downward facing triangles in the timeline. I tried to figure out what they are, and get rid of them, but have not been able to. I’m not sure they haven’t been there in the past, but I haven’t noticed them before.
The other thing, which I doubt is the cause of my inability to record, is I noticed tonight that my recording volume and playback volume are moving in tandem, which I don’t want. When I raise or lower the volume on one, the other moves to conform to it.
I tried closing and reopening Audacity several times, and also tried restarting my computer.
These did not fix the problems, nor change anything.
Any suggestions for how to fix my problems ? Thanks
