Unfinished work
Audacity 2.4.2, Windows 7
I have a unfinished task with 3 files imported for adjustment. How can I save this as far as I have gone without it being reduced down to a single file so that I can open it another day for further work?
Yes. [u]File → Save Project[/u]. (You will loose your undo history.)
It’s also a good idea to [u]Export as WAV[/u]. And, keep/save your original files too.
Thank you for the helpful reply. I can now do what I wanted!
