Undoing Envelope operations not working w/ keyboard shortcut
Hello
I’m using Audacity 2.1.2 on windows 10. If I do any Envelope operations(like adding and moving control points) and then undo with ctrl-Z, it doesn’t undo at all.
However, undoing it from the menu(Edit> Undo Envelope) works okay.
Does anyone have the same problem?
Thank you for the report. Yes it is a bug in 2.1.2. It has already been fixed in our source code, so it will be fixed in the next 2.1.3 release of Audacity (which we currently hope for in about six weeks or so).
