One more question, I looked under FAQ and it wasn’t listed. Is it possible to undo a certain effect without undoing everything done after that particular effect?
I started a new topic for you with a relevant title - that helps others reading the Forum.
No, that would be a feature request.
In some cases you can approximate it though if you can apply the effect that you wanted to undo on its own so that it applies the direct opposite of what it did originally. For example, if you applied an Equalisation you could go back to that effect, apply “Invert” to the curve you applied then OK.
