Hello.
I have a question about a weird SOLVED problem, that the solving process is not understandable, at all. Why it happens.
I got a big AVI file (683MB) from OBS-Studio, after recording output, into a file (48 Kilo Hz , 16 bit PCM).
I tried to edit it using Audacity 2.4.2.0
What i edited at first:
- I deleted the empty (no-sound) samples from the begining and the ending of the song.
- I slowed down the song by 1.75%
THE PROBLEM :
Now, I lowering the tone of the song (pitch) by 0.25 half-tones, but the software is crashing while doing the pitch editing (after about 10 seconds), so i can’t continue. It happens again, when i do the same editing process.
Now, when i open audacity, and try to recover the project, it says:
“Warning: Problems in Automatic Recovery”
“Project check found file inconsistencies during automatic recovery”
“select ‘help > Diagnostics > Show Log…’ to see details.”
the log says:
log.txt (6.16 KB)
THE SOLVING PROCESS :
I have to UNBLOCK all the NON-BLOCKED files in "C:\Users\yk\AppData\Local\Audacity\SessionData\project[some number…]\e08\d08", and then, low the pitch.
Why is that happens? Is it a known issue? Is there a way to fix it without unblock the files on any edit?
Sorry about my english, and Hope it will help someone,
Yaron.
