I saw a thread where this was an issue and the user had multiple tracks in the poject making the multiple export function break. I have one long wav file that i have split and labeled with track names. However when I got to export multiple it wont let me select use labels for multiple and i end up with the same long wave file I started with. Can anyone help? Thank you!
Screen shot attached for reference.
Those aren’t labels, they’re clip names.
You need a separate label track below the audio track.
Thank you! I was able to command B at my splits to add labels and was able to export separately. Thank you!
Yes, if you already have your songs as clips it’s super easy to add labels at the split points.
