Hi I have deleted an old version of audacity and installed 3.7. Now when i try to record it says error finding recording device error 0. It worked fine with the older version of audacity and they are both on windows 11.
any ideas?
any ideas?
What are you trying to record from? The microphone in your laptop? Etc.?
Have you selected the correct Recording Device?
Thanks for that. What I hadn’t done was to select the host ”windows waspi” in preferences. it works fine now. Thanks again
