Unable to export or save file
I’ve tried to remove or quiet the lyrics from a track. I split the track, inverted and then changed both left and right tracks to mono. Now I’m unable to save the file or export it anywhere. Any tips would be appreciated.
Why is that? What are you doing (step by step) to export? What is happening or not happening?
If the Export menu item is grayed out, try pressing the Stop button. (Most commands are disabled when Audacity is playing, recording or paused).
:wink: The Vocal Remover effect does the same thing (with some optional filtering so you don’t have to kill all the bass).
