Hi there. I am having a problem with Audacity stopping my recordings in the middle of a session.This occurs randomly anywhere between 7.2 seconds and 4’50" consistently. It is just a stop: I can start recording again afterwards, edit, etc. without problems.
I am using a MLX770 microphone connected to a Behringer U-Phoria UMC202HD interface, the connected to the USB port in the back of my Acer Aspire TC-220 desktop computer, running Windows 10 Home 1803.
Here is what I have done so far for troubleshooting.
- I have been sure to disable my antivirus and other background processes like Skype and Google Drive.
- I have tried multiple USB ports.
- I have swapped the USB cord (although both cords are middling quality.)
- I have ensured I have the latest drivers and software for the UMC202HD.
- I tried rolling back the drivers… and then updating them again when that didn’t work.
- I have updated to the latest Audacity build as of Yesterday.
- I loaded and tried Ocean Audio to see if it was an Audacity-specific problem… I had a similar experience where Ocean Audio froze and recorded a bunch of static on the track suddenly.
- I have disabled overdub, as I do not need it and it is known to cause issues with the UMC202HD.
- I defragged my hard disk manually.
- I have updated by sound card (Realtek HD Audio) to the latest drivers.
- I have disabled software playthrough.
- I have both deactivated and physically removed by USB wifi dongle.
- I have set Audacity’s resource use to High Priority in Windows Task Manager.
- I have set the project rate to 48000.
- I have set my default sample format to 16bit.
This mic and interface setup is new to me. Until recently I was using a Blue Snowball Ice USB microphone. I occasionally experienced these random stops, but it was exceedingly rare. With the analog mic and Behringer it is persistent with every recording.
I really want to step up my game, and while most of that is about me learning to record better, upgrading from a USB mic to an analog setup is a high priority for me. I am up against a deadline at the end of the month, and so I am going to have to do my latest product on the Blue Again. But I would like to have this working.
At present my planned next steps are:
- Buy a much higher quality USB cable.
- Try a different computer.
But I am very open to suggestions that don’t require me to commandeer my wife’s laptop, replace my computer, or put down money on cables.
