Two really annoying issues - crashing and upgrading
Hello,
Every time I try to save a new project, when the saving is done, the software crashes. Every single time. Why??? It’s not a lack of memory space or any of the other possible issues that were on the list.
It keeps asking me to upgrade to 3.5.1 even though I’ve gone through that process half a dozen times. Again…why??
Do you remember where you got the Audacity from? This should be the current repository.
When you install it, reset it with Tools > Reset Configuration.
What’s the show? In detail. How long is it? Are you using any drives outside of the computer. Any Drives.
There was a recent poster that had a complex show with many different sound files. One or two of them were bad, causing massive crashing and disturbances.
