Two different tracks out to an amp and headphones through interface
Hi.
I have two tracks loaded in audacity, one is the original with guitar and the other without guitar. They are lined up perfectly right now on the same screen. I have a Focusrite Scarlett Solo interface. I want to listen to the track with the guitar through the headphones and the track without the guitar through the amp. I am hooked up to each through the interface and have it that I can hear both, or I can mute the one track but it still goes through both headphone and amp together. Assuming it is a simple mouse click here and there but I cannot seem to get it to work.
Thoughts???
Audacity only supports 2-channels (left & right) for output and you can only select one input and one output device at a time.
So if they are mono tracks you could wire-up some adapters to split the headphone output.
