Turntable -> Audacity. Crossfader on mixer not working.
Using a USB turntable to Audacity. Recording is fine, but cannot use mixer/crossfader. The goal is to record mixes/scratches. Mixer is a Rane ttm56. Would be running RCA’s from master OUT on mixer → USB audio interface → laptop to solve this problem?
Yes. Or if you have a desktop/tower computer with a regular soundcard it will have line-inputs so you wouldn’t need an interface.
Connected everything and getting super low audio for recording. Everything is maxed out. Pretty much unable to record. Any helpful tips on what I need to do or what is wrong?
Connected everything how?
Have you plugged the RCA outputs into a PA system or your stereo, or something, to test the analog part of your setup? Are you getting a good signal in your headphones?
