Turned on white bars at track ends[SOLVED]
I accidently hit some key on my keyboard and now my audio track looks like this. When I try to select part of the audio wave, only the sides are selected. I’m not sure how to change it back to normal.
You have selected Multi-Tool because you pressed button F6 or possibly “A” on your computer keyboard.
Press button F1 to go back to Selection Toolbar.
Worked like a charm, thanks!
