Trying to use labels to split by silence detection but receive an error
The error says “selection is too long for nyquist code”. Are there any other plugins i can use for long (20-30hr audiobooks) files to split them up by silence/chapter breaks or anything else I can try to fix this problem? Thanks in advance.
I wouldn’t do this in Audacity. Any processing at all in Audacity requires first loading the file into a project which is typically going to at least double the size. I would explore independent tools to do this work.
