Hi, i am running Audacity 2.0.5 on OS X Mountain Lion with an M-Audio Fast Track Pro.
Sometimes I go to record, and it won’t let me, it creates a new window but then the cursor just stays at 0, blinking. Usually if I just close audacity, turn the interface off, then back on, and relaunch Audacity, it will typically work, but today it will not record at all no matter what I do. I just used it last night and it gave me no issues at all. I did launch Ableton between then and now, but wasn’t even using it thorough the interface, just the onboard output, and then I closed it to do some basic recordings into Audacity to sample later leading me to where I am now.
Can anyone shed some light as to what is going on, or even possibly a solution? Thank you.
It does that when the data stream stops or becomes damaged for some reason.
M-Audio Fast Track Pro, also known as the Avid M-Audio Fast Track Pro works best when it’s married to an Avid editing system. If you don’t happen to have a multi-thousand dollar Avid, you should make sure you have the latest drivers and interface software. The Fast-Track is not a generic use, plug-it-in-anywhere audio interface.
