It was shot on video and then post-dubbed, as the sound recordist messed up. Is there any way of improving the very flat, canned sound?
It looks like a 60Hz+harmonics de-hum notch-filter has been applied,
when it should have been 50Hz+harmonics.
I’ll see if I can find the original audio direct from the tape.
Here’s a sample, direct from the original Betamax capture.
I would just remove the first ~4 harmonics of that 50Hz mains hum
https://plugins.audacityteam.org/nyquist-plugins/effect-plugins/filters-and-eq#hum-remover
even then there’s going to be ringing as a consequence of the notches.
Betamax, before-after
Thanks - I’ve installed the plugin, but I have no idea how to find it or even use it. I must admit I’m a bit of a newbie to Audacity.
Also, is there anything else I can do you make the entire soundtrack sound less artificial and canned?
In Audacity3, (once installed and enabled), its on the old effects list in the “n/a” folder.
After notching out the mains-hum, a bit of treble-boost 5kHz-8kHz
1980 Betamax sound stops at 10kHz: beyond 10kHz is just hiss noise which should be removed with EQ or low-pass filter.
In hum remover I select 50Hz, then there is the option of an odd or even harmonics slider. I also see a threshold level - I’m a bit confused about what does what. I should also mention I have some hearing loss.
It’s possible to see what the dehum filter (rather than hear) is doing on the spectrogram
Thanks so much for your help, I really appreciate it. Here’s a spectogram with the hum removed, as per your suggested settings. The feature is around 83 mins long.
Just need to increase the treble and reduce the hiss now. What filters are best for those?
Above 10kHz only consists of hiss, a steep low-pass filter at 10kHz will remove it
Thanks - what would be best to increase the treble/top end?
Bass and Treble in the realtime effects menu can be adjusted to taste in realtime.
Using a graphic equalizer is more precise, but the native Audacity equalizer is not realtime.
Thanks - here’s a sample clip with all of the above filters applied. Anything else I could possibly do to improve it more?
Less notches:
if you notch out all the mains harmonics it adds an obvious reverb/delay effect which, IMO, is worse than the mains-hum. As I mentioned previously I would only notch the first use 4 -5 harmonics of the hum.
I used the settings you kindly suggested above - I can go back to the original file and re-do the settings, but I’m afraid I’m rather clueless about the settings/filters. Should I go back and change something?
My suggestion was 2 odd & 3 even …
That’s 5 notches, whereas the Betamax-V1 spectrum has >>50 notches.
Second attempt - with harmonics adjustments as per your post.
