Hello,
I’m using Audacity 2.0.5 on a 2008 Mac running OS X 10.6.8.
I am a music teacher trying to record rounds and vocal harmonies for my students using the built in mic on my MacBook, and headphones.
Since downloading Audacity 2.0.5, when I am attempting to recording multiple tracks and I overdub a second track, the two tracks are significantly out of sync.
I used the Latency Test with the click track suggested online, and that fixes the issue when I’m only overdubbing once on top of my original – I’ve found that I need to set my latency around -389 milliseconds.
But when I overdub a third time to add another track, the timing is significantly off from the first two. If I continue to overdub more click tracks, the 4th and 5th tracks are in sync with the 3rd track, but they are all out of sync with the first two tracks.
I tried quitting all of my other applications and turning off Airport, but the same issue occurs.
This was never an issue when I was using Audacity 1.2, and I tried downloading 2.0.3, but the same issue is coming up as with 2.0.5.
clicktest2.aup (1.8 KB)
clicktest.aup (3.21 KB)
