Tracking Best method
Hi,
Just seeing what the best method is to track one sided record?
I have 100 records to convert but i don’t want to sit and listen to all of the songs.
Is there a fast way of tracking each record? I just want to let audacity record the whole record and then label and track each song and then burn it onto a CD with the appropriate label/name of song.
Thanks,
Ron
General advice is no - don’t use high speed transfers. The RIAA EQ will be inaccurate and you are likely to lose high frequency signal.
Do it in real time, enjoy the music.
See this set of tutorials from the manual: http://manual.audacityteam.org/o/man/tutorial_copying_tapes_lps_or_minidiscs_to_cd.html
especially this one: http://manual.audacityteam.org/o/man/sample_workflow_for_lp_digitization.html
