track markers
I have copied an LP record into Audacity ready for editing. Two of the tracks are almost running into each other thus there is very little space to insert a marker. Is it possible to insert a longer break or silence section in between the tracks?
Any advice appreciated.
elleyj
Just place your cursor in the gap between the tracks - and then use Generate > Silence
Use the dropdown to select the length of silence you need.
